Author Topic: My new layout design.  (Read 164191 times)
« Reply #1650 on: November 17, 2024, 07:21:52 AM »
so after lots of cutting I have a pile of styrofoam strips which I then glued together.
« Reply #1651 on: November 17, 2024, 07:25:21 AM »
Then I mixed some plaster of paris and filled the squares.
The result 25 x 25 x 4 mm "concrete" slabs.
First 14 done, now I need to make lots more.
Still need to clean up the edges a bit with sand paper.
« Reply #1652 on: November 23, 2024, 07:12:30 AM »
That's a cool idea....... Nice one Jörg  :biggrin:
« Reply #1653 on: November 24, 2024, 02:03:10 PM »
This is my plan. Still need to produce a lot more tiles.
« Reply #1654 on: November 24, 2024, 02:05:16 PM »
In the meantime while some more plaster sets on the kitchen table I am busy
on my turntable.
First paint to weather the wood.
« Reply #1655 on: November 30, 2024, 03:56:21 PM »
so after looking at my 25 x 25 mm tiles for a few days I decided to try bigger ones.
Made a new mold and produced a batch of 50 x 50 mm tiles.
I like these much more.
But now do I lay them centered along the center line on the right in the picture?
Or do I lay them along the center line to each side as I have it in the left of the picture?
Any feed back please.
« Reply #1656 on: December 02, 2024, 12:37:41 PM »
Very nice Jörg,
Mmmmmm, think I would do the center full tile and then cut the sides. Might look better when you look into the round house.
« Reply #1657 on: December 03, 2024, 06:44:51 AM »
What he said… :innocent:
« Reply #1658 on: December 03, 2024, 05:15:01 PM »
so after looking at this for a day or two I decided to lay them along the center line.
I've only done four of them, they break easily.
First two.
« Reply #1659 on: December 03, 2024, 05:16:54 PM »
I have to undercut them on one side so that they fit over the ties and can be snug
to the rail.
Four done.
« Reply #1660 on: December 03, 2024, 05:18:29 PM »
But now I understand that you think I should do it the other way.
Let me sleep over that a night or two.
« Reply #1661 on: December 05, 2024, 07:40:07 AM »
I wonder....... what if you built a grid out of paper or thin card, then you place that inbetween the track and pour the plaster in each grid square.
Let it set for hour or so and then pull the card out. Then you should get a nice looking edge and no cutting and filing required  :biggrin:
Hope this make sense, else I will try to explain better or we can chat on Saturday.
« Reply #1662 on: December 05, 2024, 10:35:47 AM »
Now that is a nifty idea.
This sanding and filing is making a huge mess.
« Reply #1663 on: December 05, 2024, 11:00:23 AM »
Now I'm trying to figure out what material to use that doesn't stick to the plaster.
Any ideas?
« Reply #1664 on: December 05, 2024, 11:25:02 AM »
In the meantime I've been busy on my turntable, fitted light in the operators shed, as well as a flashing yellow light
on the roof of the shed that will flash while the turntable is operating.
New decoder fitted, with all wiring for signals as well.
